HudsonScannerGuy
I might be getting a Kenwood D74 for Christmas. What are the pros and cons you guys have found out that the websites dont list?
Huh. Okay. I'll have to check it out. I shouldve gone with a D72 as my first APRS HT I guess...Only has half the functions (no TNC) and data display is crippled. You'll easily see the difference next to the kenwood.
I'm not a regular user of APRS, so you'll have to search that up. I remember a lot of hams complaining about the APRS in the FT3DR facebook forum. I think APRS in the Ft2 and Ft3 is the same.
Rereading what I wrote and your replies. I just wanted to make sure of this, APRS in the D74 is superior to the Yeasu HTs.Huh. Okay. I'll have to check it out. I shouldve gone with a D72 as my first APRS HT I guess...
Do you find the HF recieve a plus too? I would figure that's a major plus in some ham's minds...I had a TH-D72 before I got the TH-D74. I also have a Yaesu FT-1DR and an FT-2DR.
Pros: Full access to the TNC. This will allow you to fully use third-party APRS programs such as APRSIS/32 or PinpointAPRS. You can also use the TH-D74 to access Winlink packet stations. The receive and transmit audio equalizer is a plus that few people actually use. Compared to the Yaesus, I find the TH-D74 very easy to you. The things you use on a regular basis are assigned to front panel buttons and there are two front panel buttons that you can assign to functions at your discretion. The menus are laid out logically and easy to access.
Cons: It ain't cheap. The clear plastic lens on the display sits flush with the front panel. If you put the radio down on its face, you risk scratching the lens. Battery life is an issue that you can mitigate by shutting off things, like the GPS receiver, if you aren't using it. I've had spotty success with non-Kenwood battery packs. The Bluetooth works very well for communicating data with the radio for programming or TNC access, but I have heard of people having programs using the radio with a Bluetooth headset.
I took my HT apart, it has a huge metal chassis. The antenna connector is firmly attached to the chassis.I don't like SMA-Female antenna connectors. Fragile. Be careful changing antennas and/or get a SMA-BNC adaptor that snugs down on the radio body, thus relieving stress on the connector - and leave it on forever.
