The answer from Uniden about Digital Problem
Sjinndoawi
South Florida
The current digital scanners, even upgraded to the most recent firmware (where applicable) do a poor job of handling simulcast transmissions on any system using P25 . This is most often noticed by a breaking up of a fairly strong transmission that one would normally believe to be crystal clear.
This problem is due to the scanner receiving multipath signals and not being able to properly correct the digital signal so that the audio can be recovered. When receiving multipath signals from an analog system you may hear just a bit of wavering in the signal and your ear/brain has no trouble detecting the correct sounds coming from the speaker. Shortwave signals that suffer this cause more trouble in single sideband (SSB) due to the nature of the way the signal is handled and those of you who have experienced listening to multipath SSB are well aware of how tiresome it is to listen to. In a digital signal, the IMBE vocoder in the scanner must detect every bit (0 or 1) that is coming in, assemble these bits into a packet then translate this stream into an audio signal that is understandable by us. The problem comes when this multipath signal is just not exactly the same (due to time/distance issues) when received by the scanner and the vocoder has trouble correcting the slightly out of sync signal it is receiving. This results in a broken transmission, usually resulting in what a lot of folks call a "pixelated" signal. It usually manifests itself as a readable signal followed by a broken signal then back to a readable one, etc.
If the above situation was present in real radios (the ones actually used by the subscribers), then P25 CAI (indeed any digital signaling) would not be acceptable for a public safety use. It should be pointed out that this multipath distortion is much less prevalent in real radios but in fact this does happen a little to real radios. You may hear some user actually comment about it when asking someone to repeat something that "broke up" when you heard the requested repeated transmission just fine. In addition, the system engineers have the advantage that they can "tweak" the actual system's timing values until the problem is all but eliminated.
Since we, the scanner hobbyist, are not paying really big bucks for a system that must work properly, the error correction algorithms used in the scanner to deal with this problem are not nearly as strong or as good as those used in real radios. This is not particularly the manufacturer's fault but rather a situational problem. To properly come up with a better algorithm for error correction, the software engineer must be able to "tweak" the code by repeated trial and error. And once it works for system 'A', will it work as well for system 'B'? Also, if the specific system that you are listening to has not been "tweaked" to the exact right specifications, this will just exacerbate the problem for the scanner user. Remember, actual systems can be adjusted properly or nearly properly and that one variable can cause us problems.
There is no "one" solution to this problem; however, there are things that you the scanner user can do to mitigate the problem depending on your situation.
* If you are closer to one site than another, you may not experience this problem at all. This explains why in discussions about the problem on specific systems, some people find it intolerable while others hardly notice it at all. This leads to one solution for base station monitors; a directional antenna pointed at the site you want to monitor. If you are receiving all of the signal from only one site, there is no multipath distortion to deal with. This of course does no good for people who are mobile.
* Attenuation of all the signals sometimes helps. This is of course due to the fact that if you attenuate the signals you possibly lose the ability to hear the interfering signal from the multipath source.
* Keep your firmware updated in your scanner. The scanner manufacturers are indeed addressing this problem as more and more of these simulcast digital systems come on line. Of course sometimes it may seem that the most current version of firmware takes a step backwards, but due to the fact that each system is unique, it may well be that worked better on system 'A' actually causes system 'B' users to notice a backward step.
werinshades
Chicago , IL
This sounds like Starcom 21 !!! Thanks for the information...
PeterGV
K1PGV
Mont Vernon, NH
All very true, and interesting, I'm sure...
Can you put this in context?? Your topic title says "Answer from Uniden", so are you implying this was written by Uniden?? In "answer" to what?
Or is this a treatise that you've written to help elucidate the readers here?
de Peter K1PGV
n4yek
Cosby, Tennessee
de Peter K1PGV
If you ever monitored P25, you would know the question.
The informative thread this person started pretty much tells you the question right in the beginning paragraph.
rdale
Lansing, MI
I don't believe that's direct from Uniden, I highly doubt they refer to their company as "we, the scanner hobbyist" and admitting that users "are not paying really big bucks for a system that must work properly"
gregmoss
Alaska
Hummm! The answer from Uniden about Digital Problem. Sounds abit odd too me.
Sjinndoawi
South Florida
Not from Uniden but the tech I talked to there stated this not word for word but directed me to a site. So I am implying that maybe this is how they feel at Uniden about the hole digital problem...
PeterGV
K1PGV
Mont Vernon, NH
Ah... THAT's the context I was looking for: It's NOT from Uniden. It's part paraphrasing what "some guy" at Uniden told you and part your concept of what the problem might be.
Thanks for the clarification,
de Peter K1PGV
a29zuk
SE Michigan
I would like to see it pick one tower with a strong signal and lock in on the one tower and ignore the other towers. Each tower,even though on the same frequency, must have its own identity. If you are mobile it could switch towers as you are moving closer to the next tower as it does when you are moving county to county on a non-simulcast digital system.
Deeke
And the site that you were directed to was?
rdale
Lansing, MI
That is incorrect. That's why it is called a simulcast - every tower looks identical to every radio.
And think about it -- two towers are transmitting on 868.000MHz. Both have a fairly strong signal. There is no physical way your radio can ignore "one" of the transmissions it is getting.
GTO_04
Noblesville, IN
Very true!
What is the reasoning behind using a simulcast system? Simply the fact that fewer frequencies are required?
GTO_04
rdale
Lansing, MI
Not just fewer frequencies - but since every tower is the same, radios don't have to go hunting for new control channels. So for example my county has a 6-tower system with 10 freq's each, so you'd need to program the radio with 6 different identities (not sure that's possible) and 60 frequencies (certainly not possible!)
GTR8000
NY/NJ Database Guy
BEE00
The primary purpose of simulcasting is to ensure seamless, uninterrupted coverage over a large area, or one that is broken up by varied terrain.
a29zuk
SE Michigan
OK I see. I realized they all shared the same frequencies. I thought maybe each tower had an identity like a cell phone tower.
Thanks for the info!
