The "InTenna" covert CB antenna by Microwave Filter Co. The unboxing
FPR1981
Sweeping that RG-58 would be interesting.
I have an MFJ antenna analyzer. I might do that just for poops and laughs.
This kit is in extremely good shape and has not been exposed to the elements. Do you think the coax is likely still stable?
And, upon studying the instructions, I am going to have to adapt the mounting procedure, so as not to land me in divorce court after drilling holes in my wife's beloved Honda Pilot. I may also swap out some of the original mounting gear with 3M Command stuff, as it is less likely to leave any "evidence" behind.
prcguy
I've installed a lot of those things, maybe 30 or 40 of them. The larger the car the better and a Honda Pilot car body will not radiate as much as a Ford Excursion. You MUST ground the tuning box on one side of the window and you MUST ground the wire at the opposite side of the window. That's how the antenna works, its basically a gamma match across a large opening in sheet metal making a "slot antenna", and the circumference of the window opening and the skin of the vehicle becomes the antenna.
FPR1981
Any suggestions on identifying and utilizing ground points in the least intrusive manner possible?
prcguy
I installed these in the mid 70s until the early 80s and cars were a bit simpler then. I would usually peel back the window rubber and headliner material around a window to inspect the sheet metal to see if its safe to drill then after drilling I would see how deep the hole is and if its safe to actually put the screw in. I would usually drill the hole with headliner material out of the way in case the hole was too shallow and I had to move further away from the window opening and hide the first hole. Some cars had very little space between the inside and outside sheet metal right at the window.
I would then mount the tuning box as close as possible to the window rubber and the same for the wire lug on the opposite side without cutting the wire yet. Then I would carefully determine the length of wire needed to make the wire taut across the window buy cutting and stripping the end, sticking the stripped end into the lug while its screwed down, then taking off the lug and soldering the wire in the lug with some heatshrink over the connection and finally screwing the lug with attached wire back down.
Sometimes I could loop the coax from the tuning box towards the rubber window seal and tuck it under the rubber until its off to the side and can take another route to the radio. These almost always went in a back window but I had to put a few in the front window per customer request. I also put some across big sliding windows in motor homes and campers.
FPR1981
This recommends the front windshield.
FPR1981
In my Accord, I can peel back the headliner and make contact with the metal body panel lip pretty easily. I'm going to do a temporary install at most, so as long as I can ground out for the demonstration I'm good
FPR1981
What about making use of a moon roof instead of the windshield
FPR1981
I scored myself a 1995 Chevy K1500 pickup with the Z71 package, a downright belligerent 350 with a 2-chamber Flowmaster and think this would be the perfect vehicle to put the InTenna to work in.
Could I install it in the back window?
n9mxq
Belvidere IL
I've got one that adapts the stereo antenna for a CB. Doubt it would work on todays more "stubby" antennas, but have thought about using it on my Dodge Ram just for kicks.
FPR1981
I actually have three NIB Turner Signal Kicker disguise CB antennas that are a direct replacement for your AM/FM antenna, but made for CB. I am also going to test one soon.
slowmover
Fort Worth
Naw. Need a SIRIO BIG BULL L.E.D. Trucker Antenna.
Key up, and light ‘em up
Th
ats until you’ve got the green for a pair of QUAKE led triple-color cb antennas. Co-phase redneckin’ with a gennywine Bubba Fred old school splatterbox
