The "K" beacon
majoco
New Zealand
...coming in clearly tonight on a different frequency than normal, on 10872kHz at 0623, with lots of buzzes and bangs at the same time.
see here...
Letter beacon - HF Underground
He's also on 13528kHz which is also a new one for him, as well as his normal 16332kHz. Also on this freq is the "D" beacon. The "P" beacon is on 7039.4kHz where plenty of hams try to drown him out.
Now (0652) the "M" beacon is starting to come thru on 13528kHz.
