The Soft66lc2 SDR
surfsup28
Sydney, Australia
Hey guys..have recently purchased a soft66lc2 SDR radio from a bloke in japan on ebay for a about $100 AUD..Its very sensitive and works very well as a general coverage HF reciever, with a desecent antenna connected to it. And for the size of it, it is very compact which u can take anywhere..receives from MW bands up to about 30 Mhz.
This is the website... Soft66AD
Some may not agree thats its a good reciever looking at its size, but have used it for a few months now and it definately can hear signals worldwide..using most of the SDR software programs, that are freely available, such as HSDR, winrad, etc.
Looks interesting. I wonder why they need a "Line In" cable though... I thought true SDR was sending the I/Q data thru USB and then the software does all of the decoding...?
Token
DDC SDRs do as you have described nickcarr, but sound card based SDRs (like the one in this thread) send the I/Q to the computer in the form of L/R audio inputs. And then the ADC in the sound card brings the data to the computer for processing.
Sound card based SDRs are a lot of value for the money. For about the cost of a mid market portable you can get a sound card based SDR that will outperform pretty much every portable on the market in several ways. In many ways it can perform at a level of most entry desk top SW receivers, such as the Icom R-75 or the Alinco DX-R8T, in some ways, such as filter settings and filter performance, it can exceed these radios. Typically the desktops will have a slight MDS or sensitivity advantage over the sound card based SDRs though. But the average user might not notice this sensitivity delta.
However, sound card SDRs do not perform at the same level as a DDC (direct digital conversion) SDR (such as the RFSpace SDR-IQ, SDR-IP, NetSDR, Microtelecom Perseus, WinRadio Excalibur, etc). Particularly in areas such as dynamic range, close signal rejection, and image rejection, the DDC SDR will be significantly better. This is primarily caused by channel to channel phase relationship issues on sound cards, even the best sound card is not designed to tightly control the phase relationship across frequency that would help the sound card SDR.
Also, the best sound card and sound card SDR combination cannot give you the instantaneous bandwidth of the lowest end DDC SDRs, and not even 1/20 the bandwidth of higher end DDC SDRs. Typically the sound card SDR yields something less than 190 kHz of range, with 90-100 kHz being a common max width, while the lowest cost DDC SDR yields 192 kHz, and bandwidths of 4 MHz are possible at reasonable prices.
Still, even with the shortcomings of the sound card based SDR most of them perform at a level that is quite good, and would not have been possible for ten times the money a few years ago.
T!
surfsup28
Sydney, Australia
Soft66lc2
Great response TOKEN , couldnt have said it better myself. Yes the SDR is quite good, but does have a few issues as you've outlined. Its not as good as the higher end SDR,s on the market but beleive me for a small size (approx the size of 3 x match boxes)...it does extremely well for a budget HF reciever. I was amazed how well it actually worked when set up correctly using it with a descent sound card and antenna. In my books it was worth the money compared to buying another HF reciever at more costly price.
