These are the bands I receive. Any suggestions on what I can tune in?
spilot113
Massachusetts/New Hampshire
Thanks for the assistance from the experienced people on this board. You've been very helpful.
My radio receives these frequencies bands.
108-137 mhz
137-144 mhz
174-400 mhz
400-480 mhz
480-999 mhz
I have found some police, fire WX and airports.....anything else interesting I should be tuning for?
ecps92
Taxachusetts
108-137 mhz
137-144 mhz
174-400 mhz
400-480 mhz
480-999 mhz
you meant 137-174
Tons out there, Police, Fire, DPW, EMS, Aircraft, Milair etc
what type of radio ? as most PD/FD are now P25 in that region
Also update your RR Profile, that way folks won't have to ask where are you from
kc2asb
NYC Area
+3 on using the search feature on your scanner and looking for frequencies for your area in the Radio Reference database.
What radio are you using? If it's not a digital scanner, you will not be able to monitor any frequencies listed as P25 (or NXDN, DMR, MotTrbo, etc) in the database. Encrypted frequencies, marked with an "E", cannot be monitored on any scanner. (A small "e" next to a frequency means partially encrypted, so you will hear some communications in the clear). We can tell you if your scanner is digital if you provide the manufacturer/model number.
bearcatrp
Land of 10,000 taxes
Best to scan between those frequencies. RR doesn’t have all frequencies in the database. If you find one not in the database, send in to RR for it to be added. Good luck
