Thoughts on EF Johnson radios
Chimpie
Sarasota, Florida
Has anyone used EF Johnson radios? We're looking at buying a set of EF Johnson 800 mhz 51SL/5100 ES radios and would like some end user feedback. Even if you haven't used this particular model, we'd like to have your thoughts on their products in general.
Chimp
b7spectra
EMS Dispatcher
Cobb County, GA
City of Marietta (GA), works off of the Cobb County P25 TRS, but they said NO to Motherola on purchasing their equipment and went with EFJ. Apparently they got a hell of a good deal and they should be coming on line very soon!
SEMTTP
Ypsilanti Michigan
I agree. EF Johnson radios are cheap. That is why these departments buy them. They are not a good radio. The buttons break and they lose signal. Pieces of garbage in my opionion. These Motorola systems are designed for MOTOROLA equipment.
Portable14
Banned
Connecticut.
I agree.
I've used EF Johnson equipment, And I must say, I don't really like it, The batteries die quickly, The belt clips break easily, So I can the only thing I can say that I like about them is the range, But that's only good when you're running a lot of power and a good antenna.
