When the digital threshold mode is set to auto, how often does the x36 adjust the level?
What triggers the adjusting?
73, john
It is constantly trying to adjust the threshold but it does not work very well for simulcast sites or weaker signal levels. In these cases, it seems to hunt around and often makes things worse.
This can be seen on the prior models, the x96XT series which do not have a true manual mode.
The older x96T models as well as the x36HP models all have true Manual mode settings which should be tried if you are experiencing broken audio.
I'm able to use manual mode here for a couple simulcast sites and that was all it took to clean up decoding and give me clean audio. auto mode just kept trying to adjust but never got it right until the chatter was about done.
For my 996XT models, I simply cannot use them on these sites even after trying to tame down the auto mode adjustment range which is available from a hidden menu. It helps some but not near as well as the true manual mode does that is offered in the other models mentioned above.
I'm not certain what triggers it to adjust but I'd guess it watches the same Decode Error info you can see on the screen while a transmission is being received. If it sees errors, auto mode should try and adjust for zero errors but it seems to overshoot and miss the proper value. In my case, when auto mode is used and the radio is seeing errors. it seems to adjust in the wrong direction starting at 8. I need a value of 6 or 7 but auto mode goes up and tries higher values which just makes things worse. By the time it may try a value below 8, the transmission is usually over.
5 seems to be the lowest possible setting. This is with P25 sites here,
