Is there anywhere where the PROPER hole sizes for different type mount s are given? PL-259 is that 3/4" and NMO is that 1 and 1/8"?
LarrySC said:Please dont drill a hole in your roof. Use an L-bracket if you can. Mounting holes are into fender LIP. I use L-brackets with 3/8" hole for the NMO mounts. Look at photos. www.bncantenna.com
How exactly is that done? How would you secure the mount? It would seem like it to be nearly impossible to do without dropping the headliner down.jim202 said:You don't have to have access to the underside of the hole and normally snake the coax cable between the roof and the headliner.
yay! That sounds easy. I think I will quit my day job and open a radio shop.TeRayCodA said:-You're done!
How would the mount be secured? Isn't there a nut that needs to be tightened on the inside?flyingwolf said:Or you could still use the domelight area and simply run a sligly longer coax.
LarrySC said:Jim202 has the wrong idea. My radio shop has been in one place 35 Years. The reason I dont like roof mounts is because most people at one time or another will forget and whack one of them off in a parking garage. So you try to get a body shop to fix that. I sell them what ever they want and let them install or have someone else to do it. They may work better on the roof and if its a small car or truck, OK. If its a B1G truck/suv then be carefull. Good Luck to all. Larry
crayon said:How would the mount be secured? Isn't there a nut that needs to be tightened on the inside?
I have never seen a MNO mount or one being installed. But I would like to try it sometime .. just need to get these questions in my mind answered that I have always had about MNO mounts.![]()
Hope that made sense to you.
