Thunder Bay OPP
Mark_Space
The Great White North
Hello, All...
I was wondering if someone could point me in the right direction on TBay OPP frequencies.
I've just moved here, and am in the process of populating my 296D with local freqs gleaned from the Web, the RR Database, and even an old copy of Haruteq (circa 2001). Unfortunately, nothing tells me what the OPP uses in the TBay area.
Fiddling with TAFL yields a bunch of freqs in the 140 MHz range, licensed to "Her Majesty the Queen"; not exactly what I'm looking for, and nothing in the listings for Zones 1 - 3 appear to be in the local area. Any suggestions?
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
That section of the OPP still uses the old NOR system. I would check this Web site and see what freqs are the most active in your area. You will hear a constant squaking when the channel is ready for use.
When you hear something, let us know what you find.
73's
Ron
IdleMonitor
The Ottawa Valley - Eastern Ontario
Even though that system is being phased out, he'll still also want the input frequencies for the repeaters.
I submitted them to the database a long time ago but no one ever bothered to put them in.
Mike_Oxlong said:
Better yet, check the radioreference database:
http://www.radioreference.com/modules.php?name=RR&aid=577
Scroll down to the NOR Areas section and plug those in your scanner. Just make sure you use the 107.2hz tone on the NOR channels.
DaveH
Ottawa, Ont.
Regardless, the inputs are listed in Haruteq books.
Dave
IdleMonitor
So what you're saying is there's no need for them in such as a database like radioreference.com So you refer the person to a book that's been out of print for how many years now.
Regardless, they should be in the database. Maybe not so much anymore because of the system being phased out, but they should've been in there a long time ago, because well, you do need the input frequencies in order to listen to the NORS repeaters properly. Not all the time will you hear the whole conversation on the repeater side of things.
Geez Dave of all people I would've thought you would've been the first to realize that.
Oh well, atleast he can get them on the old website that was referred earlier in the thread.
Dave
polo_762
Forgive my ignorance...but where does Fleetnet Zone 3 coverage end? I mean, I'm sure that places like Thunder Bay, Chapleau, Kenora, Moosonee etc are out of range...but where does it start?
Mark_Space
Thanks!
Lot of good suggestions. I've loaded everything into my 296D, so we'll see what happens. Unfortunately, my office is somewhat opaque to RF, so my listening will be confined to the evenings at home...
I'll post my results when I've got something worth reporting. Thanks again...
als_medic
I moved here recently as well. Here is everything I have for the City.
Hope it helps.
For OPP in Thunder Bay: (All have a CTSS of 107.2)
140.97000 SIM 1
141.39000 NOR 1A
141.19500 NOR 1B
141.45000 NOR 6A
141.54000 NOR 6B
141.55500 NOR 7A
142.36500 NOR 8A
142.66500 NOR 8B
143.64000 NOR 9B
Thunder Bay Fire:
153.80000 Fire
154.19000 Fire Dispatch
172.11000 Fire TAC
406.61250 Fire Paging
First Response Teams:
149.11000 Shunia FRT
150.20000 Gillies/Neebing FRT
152.13500 OPR/Conmee/Hazelwood FRT
Ambulance:
150.48500 Thunder Bay District
149.71000 NOARS 1
150.75500 NOARS 2
149.80000 NOARS 3
149.33500 NOARS 4
150.10000 PCOM
149.60500 PTAC
148.65500 INTERAGENCY
129.27500 AIR/GROUND
413.68750 AIR AMBULANCE
149.44000 BASE PAGING
