KJ4FWA
Is it possible/Wise to "Tie" two antenna together in the cable Via a splitter into one cable. Would they work together? or would this be more problem then it's worth?
chedderhead said:Is it possible/Wise to "Tie" two antenna together in the cable Via a splitter into one cable. Would they work together? or would this be more problem then it's worth?
Definitely! But I want BOTH antenna signals going to the receiver, not just the 800. Otherwise, I would simply run two separate cables to two separate radios.Lowa2 said:All that being said, if you would run 2 coax cables up there, it will most likely be cheaper, more reliable, and would work much better.
Lowa2 said:just put an isoator on the 800MHz coax. Using the 800 MHz antenna on port 1, port 2 on the coax going down to your radios.
http://www.e-meca.com/specs_iso_cir/specs_iso_cir.php?ID=10&SpecsID=5All those components are pretty expensive, but would do a pretty good job if all the cables are phased correctly.
zz0468 said:I see a number of flaws with your system. First, that 800 MHz filter is going to present a severe mismatch to the amateur radio. Since at frequencies other than 800 MHz, the filter is not a 50 ohm impedance, the first splitter will not provide it's specified isolation between ports, nor will it provide the specified impedance match.
The second major flaw in your design is the circulator. What may behave as a circulator at 800 MHz may look like a dead short at vhf/uhf. While circulators can be rather broadbanded, finding one that would actually provide the proper isolation on one band, while providing the proper low loss transmission on another band is goint to be difficult at best. And when is the last time you bought one that meets those specs? The one in your link certainly wouldn't cut it. The cost of the circulator alone would greatly exceed the cost of a second antenna and feedline.
The third major flaw is the requirement of critical length cables. Remember, the tranceiver is a dual bander, complicating the critical length.
I hate to say it but, while I see where you're trying to go with this, in reality, it wouldn't work as designed, and the the components required would be prohibitively expensive, that is, if you could find them at all. I'm in 100% agreement with your final comment that two antennas would be cheaper and more reliable.
To af5rn, what you're trying to accomplish would be best handled with a wideband antenna for the scanner, and a dual band antenna for the ham rig. But I've developed some ideas on running several radios on a single antenna involving coaxial relays that avoids critical length cables and expensive exotic devices such as very broadband high power circulators.
A commercial tranceiver combiner to allow several radios to share a single radio costs several thousand dollars, and is useable for a single band only.
af5rn said:Yeah, I was kind of afraid of that. The original theory was that running an all band scanner off of a 3db 800 antenna and a 3db dual-band antenna phased together could result in better reception than a single unity-gain tri-band antenna, like the BMAXSCAN1000 or the Spectra. Still makes sense, but is looking less and less practical.
Thanks for the input!
Lowa2 said:Don't worry, I know that most of what I said was flawed, but i missunderstood what the op wanted to do...
