Tips/Tricks for Band Plan Data
timkilbride
Linn Co Iowa
Does anyone have any tip/tricks when programming in a system and you don't have the band plan data? I'm headed to some areas that are covered with VHF/UHF phase 2 systems. I don't think my 7/800 band plans will do.
Tim
Reconrider
Inside the Galaxy
Radio Galaxy
Ask someone around that area or make a post in the state forum
mid you have it, bring computer sdr and run dsd on the system
IFRIED91
Arrive alive
NYC area
Depending on the type of system… Motorola 7/800mhz phase II will always have the same IDEN data usually…. Only things to remember is Harris systems alternate control sites so all frequencies must be set as control channels… VHF/UHF phase II systems… yeah you’re on your own those can be anything and have any and all sorts of IDEN data arrangements…
Com-Tech51H8
bureaucratic absence of presence.
BEE00
SDRs are fairly cheap and ive used mine on several fox hunt senarios as well as tracking band plans bluetail tech( i think is the company) or theres other ones do your research
