TK-2207 Questions
Whatcom County, WA
I am new to this whole deal. I work with a public agency and have purchased a TK-2207 and am having trouble finding information on this radio. I have since figured out it is not typically sold in the U.S., is this correct?? Also, any ideas on getting the programming software for this unit? I have the cable and radio being shipped, but can not find software. I hear Kenwood keeps their software pretty lock-tight.
Thanks for any help
ramal121
Lots and lots of watts
Calif Whine Country
Looked and there is no TK-2207 in USA price pages. It has 2200L and 2200LP. Software would be the KPG-88D, but it does not reference a 2207 either. Not sure what market thats for.
ambdrvr
Kenwood TK-2207
Hello,
I did some looking around and found that the 2207/3207 models are marketed out of Singapore. I also located the software for these radios which is the KPG-87D. Hope this helps out.
Ambdrvr
N2MRG
Sorry this is so old, but I just picked up one of these radios from ebay
I can program fine, at least I can program TX/RX frequencies and CTCSS tones and I can hook the local repeater. It is very local, so it doesn't say much for what kind of distance I am getting.
I can't seem to use the "radio information" link in the software. I can't program the second button (bottom most button). Software is KPG-87D.
Finally, and most importantly to me. The transmit audio is extremely muffled. I know this is a $65 radio so I should not expect much, but does anyone have any advice or have experienced similar issues?
N2MRG
I talked to some of the guys who posted the warnings on eBay about these radios. One guy bought a bunch of these and had luck by opening up the mic hole and removing the microphone cover. I decided to open up the case and do the same. I tried 1 - opening the hole up and 2 - removing the microphone cover which is a sort of rubber cover with a small opening in the middle of it. Neither of these helped at all. The audio is very muffled still. The seller has agreed to send me another body for a minimal cost that we're going to try.
Another problem is putting the chassis back in the case. It is rather difficult to get the buttons to line up properly for some reason and I managed to rip the speaker leads off the PCB, so I wouldn't recommend it unless absolutely necessary. Entirely fixable, but more hassle than it is worth.
Overall, I would recommend that if you're looking for good audio out of this radio, an external mic may be necessary. The problem is that I want this radio to be easy to use, small form, and water resistant. So I will check the next unit to see if the audio is better... if not I will tolerate the muffled audio in exchange for it's water resistance and portability.
VE1GAT
Secular Humanist, goodness without godness
Halifax or Englishtown, Nova Scotia, Canada
kenwood announced awhile back that Singapore,
Announcement:
This announces Kenwood Electronics Singapore’s decision to formally terminate the TRACKGENUINE program that was initiated in 2006. The program was conceived as a counterfeit deterrence measure from Kenwood Corporation which allows consumers to verify the authenticity of the Kenwood products purchased through authorized dealers.
We thank you for your continuous support to Kenwood.
Kenwood Electronics Singapore Pte. Ltd.
Please note that this authentication service is only available Kenwood Radio Communication Product and limit to certain models in the following countries: Malaysia, Sri Lanka, Thailand, Vietnam.
And the models are KNB-35L-M, TK-2107, TK-3107, TK-2207, TK-3207, TH-K2AT.
Kenwood Corporation | Track Genuine
does that mean counterfeits have taken over?
the software is kpg47d
and you can download from the radio but not upload to it with a Baofeng UV5 USB programming cable.
I will look into if modifying the wiring to the 2.5mm & 3.5mm pins will do the job of uploading.
