Tk-2312 programming help
Wfd7715
My FD just bought 20 TK-2312's and I am currently trying to program them. I have been programming our radios mostly 2180's and 790's. This is my first time dealing with the 2312's. I have 5 zones programmed after I write it to the radio and go to change the channel using either B or C it changes but the zone name stays, I can not see what channel it is actually on. And help would be greatly appreciated!!
Wfd7715
That did not work here is what everything is set at as far as key assignments;
S:scan
A:scan delete/add
<B:zone down
C>:zone up
Side 1: squelch off momentary
Side 2: lamp
Selector:channel up/down
O:Talk around
&#9633;:key lock
Triangle:monitor
ohiohonda
I would look under the optional features tab > common 1> display character and see what this is set for. I would have this set for channel name. Also under optional features tab> common 2 > Zone name text length and the zone name check box. I would set the zone name text length to the shortest possible for the names that you are using for the zones and check the box for the zone name. Using these settings will have the radio display the zone name for 2 seconds after a zone change then revert to the channel name.
03msc
RF is RF
The Natural State
Zone Name Length = 8 will show the full length of the Zone name for 2 seconds. UNCHECK the box below so that it goes away, otherwise it remains on the display. This was my experience, at least.
When I left the zone name box checked it just stayed on the display. Unchecking it makes it appear for 2 seconds and then go away.
ohiohonda
I am not as familiar with this model so this may be the case. I was just quoting the help file within the program. It states that if you uncheck the zone name box that it does not show the zone name when changing zones. If you check the zone name box that it will display the name for 2 seconds then revert to the channel name.
03msc
RF is RF
The Natural State
Confused the heck out of me, too, but I have mine setup as I described and it shows it for 2 seconds. I just had to trial and error it to see how it worked.
