TK 3140 Setting up Caller ID
schwartznet
About a year ago i programmed all our TK 3140's with caller id so that when a mobile transmits its id is transmitted as well. This was great but now we have to update radios swap them ext and i forgot how to program it. Can someone help an old man out. I have KPG74D 1.11. These are not on a trunking system. Just simple line of sight.
LowBat
San Jose, CA
Try looking under edit > optional features > optional features 2. On the right of that window you'll see PTT ID settings.
ramal121
Lots and lots of watts
Calif Whine Country
Guess you're doing this with fleetstink. Go to the Fleetsync menu and set your fleet and ID for each radio. Also in that menu check "Caller ID Display" for each receiver that will decode and show the ID.
Now do what LowBat says and go to Edit>Optional features 2 and set PTT ID for "MSK" and whether you want it "BOT before, "EOT" after or both.
Now go to the channel you want to send it on, press "CH EDIT". Select "PTT ID" as "OWN". That will get you sending ID #s. For a name alias, go to Fleetsync>ID List. Fill in the all your fleet/ IDs plus an associated name. Now when receiving instead of a number the display will show the name of the transmitting radio.
