TK 3180 LTR Programing
amr_emt_907
la pine, OR
Hi Guys I was wondering if you all can help me out I have the KPG89D software and Im a little lost on how to get a LTR system programed on it for example in trucking zone it asks for a Encode id and decode id which it only allows up to three numbers to be entered and also doesn't the freq. have to be entered in a LCN order so it will be able to properly track the system.
ramal121
Lots and lots of watts
Calif Whine Country
At a minimum, to get a trunked system up and running, you will need the system frequency list, home channel, area code, and ID number.
Frequency list - an LTR system can have up to 20 repeaters to choose from. You need the freq list for your system and enter them in the correct slot, 1 to 20. It may have only 2 or 3, or maybe 15 or all 20, but they have to be in the right order and right slot (LCN).
Your system admin will assign a home channel (1 to 20) and ID. Home channel must be correct as this is the first repeater your radio will try to connect to. Only if this repeater is busy will the system issue a trunk off to your radio if you try to transmit. Next is ID (001 to 255). Only valid ID's are programmed into the system. Think of it like PL's. Every user gets a different ID. Don't pay for your airtime? Your ID is disabled. Normally encode and decode IDs are the same, although split IDs could be used.
Last is the area code. Usually it is set to 0. If systems overlap, one system may specify area code 1. This is used to prevent false decodes from the overlap. Use what is assigned.
In KPG89D, set a zone as trunking, go there and enter IDs (plus other info), then click "REPEATER" at bottom and fill in other info.
If you're still stuck, cry uncle...
