TK-5410D Programming Software
billyfromhill
What programming software do I need to program a TK-5410D? I'm thinking about picking one up for use on a P25 phase II system. I believe I need the KPG-95 software but there's at least three revisions out there, KPG-95D, DG, and DGN.
The "N" designation is for the narrow band software that was released in late 2012 to meet the FCC mandates.
The non-"N" software was from before that. Firmware from late 2012 and later will require the "N" software.
The "D" model radio is the P25 Phase 2 model and it uses the newer software.
"K" usually means the North American market. Just like the radios, some radio/software versions are market specific and out of market software won't work with US market radios. This is a common issue I see when someone just downloads software off some random overseas website.
billyfromhill
So would the DGN software work without the K if I'm trying to program a P25 phase II system?
I don't know about that. Never tried.
If you are programming a trunked system, you're going to need some additional stuff:
You'll need the KWD-ANK-AK access key for programming the trunked system.
The system administrator will need to help you with that.
billyfromhill
So is the KWD-ANK-AK like a physical flash drive looking thing that enables the software to program a phase II system? Kind of like a hardware key?
ohiohonda
Yes the kwd-ank-ak is a slave system key device that is programmed by the system administrator with their master system key. It is a usb hardware key. Depending on the system you may need a special kpg-95dgn to program the radios. Some system require single radio files and other special functions which requires a different software version than the normal production software.
