TK 5720 vhf
rknight8700
Having issue when trying to transmit and radio shuts down and restarts. Antenna is connected and works with other radios. Is this a software issue or radio needs to go in for service?
ramal121
Sonoma, CA
During transmit, radio draws way more amps than receive. Your power source cannot supply that much and the voltage is dropping to the point it is causing the radio to reset. Where is this radio installed? A vehicle?
