Hello Everyone,
I am working to understand one result of a successful TK-690 conversion to the 6 meter band.
Big issue is lower than expected RF output levels. VCO voltages seem to me to be correct. Following my mod, the TX and RX VCO's do not go out of lock now anywhere between 42 to 54 Mhz. These results are consistent on two modified 690's.
I have looked closely at the service manual and verified that in the radio's firmware settings that the output level is set correctly. I have tested the radio into a dummy load with an inline power meter and in a vehicle with the same results - low output. Is it possible the low output is proportional to VCO voltage?
I did not use a 1/8 inch brass slug as I didn't have that handy. Instead, I used 1/8 inch (14 AWG) 14-MAG PE wire instead. It seems to have worked perfectly aside from the lower than expected output level. Am I using the wrong material?
Has anyone found they needed to tweak the output coils as you would with GE Rangr's moved to 6 meters?
If that's the next step, would anyone who did that be kind enough to post photos?
Vy73,
Phil KB6NZV
Vy73,
Phil KB6NZV
