TK-7160 Software Question
jinman92
I have a TK-7160 and KPG-99D software for the radio and it works great, but i need MDC 1200 I.D. Is there newer version of the software that anyone knows about? My radio is compatible, but I can't find the software version.
buddrousa
You need to call your local Kenwood Dealer. Where did you buy the software? Got your receipt you should be able to get the updated version.
KPG-101DN is what is listed for your radio.
toastycookies
the far east
eh?
KPG-101DN?
How'd you get there?
The correct software for a TK-7160 / 8160 series would be KPG-99DK.
KPG-101DN is for the handheld TK-2170 / 3170 series.
source: Kenwood
ramal121
Lots and lots of watts
Calif Whine Country
Software won't get you there. The firmware of the radio needs to support MDC1200. At the time the only model that had a firmware upgrade to include MDC1200 was the X180 line.
Then when the radio supports the option you'll need to get the latest version software.
Unless someone can prove me wrong there was no MDC upgrade for the X160's.
toastycookies
the far east
There was an upgrade module for MDC1200 encoding on the X160s.
CIM-1000K-20/MDC1200
L-1057
radionerd13669
Useless Contributor
Northern,New York
If you purchase the CIM-1000K-20/MDC1200 that is programmed from a different software. The 7160 has nothing to do with the MDC1200. All settings are programmed to the board. You will need to select a few boxes in the 7160 software to make it work.The 7160 alone does not support MDC1200
