Tk-7180/8180 Display Part Help.
HT-220
WB2ZRP,WRTR873
North Port Florida
While trying to install the remote kit I broke the brown latch that secures the ribbon cable to the front display.
Is this item available separately or is it only available with the display assy?
Or any ideas how I can fix?
Vern
Union County, GA
I had same thing happen the first time I ever met a ZIF connector. I reinserted ribbon and pushed the blade (hinged brown part) back into place securing the ribbon. Hinge was broken but the blade never came out... and that was a NX mobile. Your luck might vary, but it's worth a shot. If your control head gets intermittent or fails, you know where to look.
Cognomen
Radioactive Zone
You should be able to order the entire connector asssembly from a parts place and carefully remove the brown clip. I've swapped a clip from a faulty display board onto a good display board with a broken clip.
Somebody needs to let the Chinese know there's a market for the clips. lol
Cognomen
Radioactive Zone
It's not about where the current clips are made, it's about making the clips available in bulk quantities for not much more than the cost of the plastic.
