Tk 7180 hard to hear on other radios
nick223
Ottawa Illinois
So we have a tk 7180H mobile in our new rescue. Radio worked great now for some reason a lot of our (Motorola) radios are having trouble picking up the 7180 The local kenwood dealer said it might be our mic or the radio needs calibrated? any ideas?
Av8tor56
Roswell, NM
How old is the radio? Do You have any other Kenwoods? If so just switch the mic. If it fixes the problem then you have a bad mic. Also, are you Narrow or Wide? If you're wide and the Kenwood is Narrow it'll be very hard to hear. Lastly, the radio itself might just need realigned back to factory specifications.
nick223
Ottawa Illinois
Yes, we have other kenwoods I'll give that a try. The radio was purchased this July. Also our channel is still wide but do have some channels that are narrow in the radio. By realigned you mean wipe it clean and reprogram the entire radio?
nick223
Ottawa Illinois
The company that installed the antenna used a bracket for the antenna that was to thick wasn't making a great connection with the mount.
Av8tor56
Roswell, NM
Sounds like problem solved.
Realigning the radio means to tune the frequency error back to zero, adjust deviation for both the wide and narrow channels, check that your receiver opens when it should (.2uV), that it reaches full quieting where it should (.3uV), checking and adjusting power output, etc. It's all done with a service monitor, a Watt meter, and a computer to tune the radio.
