Tk-7180 help
nick223
Ottawa Illinois
I have a kenwood tk7180 that i powered up and it worked.. then i went to put the remote head onto it but instead of using the same head i just used my other 7180 head that was already set up but it didnt work probably because i needed to use the same head as the radio. So i put the ribbon and orginal head back together and now the radio wont power up any ideas or sugguestions?
ramal121
Sonoma, CA
I would recheck your ribbon cable. Make sure it is in firmly and you did not flip it 180 when you reassembled.
