TK-730 basic ctrl head RX audio
wcu02mpa
Asheville,NC
I have a TK-730 VHF radio with a basic control head. I am trying to get audio out of the front speaker rather than an external speaker (works fine out of an external speaker). I have the correct accessory pin configuration (jumper pins 9 and 12) for an internal speaker. Is there an internal jumper I need to change or what else do I need to do???
Mike
ramal121
Sonoma, CA
You could also run an external speaker off of the control head, but in order to do this the internal needs to be unplugged. Split your head and see if the internal speaker is undone. It's pretty obvious where it plugs in...
