TK-762 2 Channel
emt603
Marceline, Missouri
I have had several TK-762 8 channel mobiles and just bought a 762 2 channel. I have the programming cable and software for the 762 and thought it would be the same between the 8 channel and the 2 channel. but when i go to plug the cable into the mic jack, the mic jack is a smaller jack. am i missing something here? does the 2 channel take different cable and software that the 8 channel does?
Mike
BirkenVogt
BirkenVogt
I'm not sure specifically about the 762, but the 730 and other 30 series used a 6 pin instead of the now-common 8-pin mic connector also. We have modified programming cables simply by cutting off the 8-pin connector and crimping on a 6-pin with the conductors in the same position relative to the center and also by simply taking a bench grinder to the plastic sides of the 8-pin until it will fit in the 6-pin hole. It still works for 8-pin radios after this has been done.
T0mSmith
The TK-762 8 channel is the "G" version. The TK-762 "original version" does 2 channels. You figured out that the non "G" version uses a 6 pin mic. The 8 pin programming cable is electrically the same as the 6 pin cable used for the non "G" version. The two outside pins are not used for programming. You can make an adapter using an RJ-11 plug and an RJ-45 jack and strands from cat 5 cable. The TK-762 2 channel does use different software. It is DOS based software. I can not remember the version, but can look it up at home this evening. The TK-762 2 channel DOES do narrow-band channels.
emt603
Marceline, Missouri
ok, got the cable to work and have found the right version of software. my next question is how do i enter a blank PL Tone in that field? i am trying to program a CSQ channel and it wont let me blank out the pl tone decode field. also how do i enter a receive only channel? i want to blank out the transmit side of the channel and again it wont let me.
Mike
T0mSmith
To delete the PL tone go to the field and use the "delete" key on your keyboard. Press "delete" once for each number and period in the field. When the field is blank, press "enter".
