TK-762H programming cable
#1
I tried using a cheap multi head usb cable to program but I could not read the radio. (KPG29D) I found in other posts that I should use a serial cable so I ordered a serial port for my computer. I tried to order a KPG-4 to serial cable from the Kenwood dealer but he only has one cable left that will work for the TK-762. He said that all the aftermarket cables he has do not work for this model. He is willing to lend out or program the radios for me. Does anyone know about a cable for sale that will work with the TK-762H for sure? Thanks.
So Cali
#3
Basically the same problem with software that does not understand the USB. I have many diagrams for the KPG4 serial cable.
#4
Thanks for the replies. So are you saying that any cable on e-bay will work? The dealer said that aftermarket cables will work for other models but not the TK-762H.
