TK-780
#1
Hey guys and gals,
I recently got a Kenwood TK-780. I got it all programmed with the KPG software.
Only issue is, I started playing with the sensor settings. This was before I knew it could hurt the device.
Everything still seems to work fine. My question is, can I reset this device back to factory defaults?
I honestly have no clue what the default sensitivity was and I don't want to leave it on a setting that may hurt it.
Thanks for your time!
Sent from my Nexus 6 using Tapatalk
