TK-790 control head accessory plug
wcu02mpa
Asheville,NC
#1
Can someone provide me the 12-pin accessory plug part number through mouser? I have the 9-pin plugs but need some 12 pin plugs. Thanks.
I assume the plug pins are the same. I am looking to get speaker audio at the remote mounted control head.
