TK-790 external speaker pinout
wcu02mpa
Asheville,NC
#1
Does anybody know the pinout for the external speaker leads on a TK-790. I assume it is with the 9-pin plug and not the 25-pin plug.
Thanks,
Mike
wcu02mpa
Asheville,NC
#3
That did it. This radio has amazing audio; it is a step up from the 730 for sure. It has very crisp and clear speaker audio as well as signal reports. I plan on remote mounting this radio. Do I run the speaker leads from the 9-pin when remote mounted. I see there is a 12-pin connector, but am not sure what that is for.
Mike
wcu02mpa
Asheville,NC
#5
Part numbers???
I see it....DUH!!!! Firemaster.....would you happen to know the part number for the accessory plugs (from mouser or somewhere else)???? I would like both the 9 and the 12 pin plugs. I got some of the TK-730 plugs from mouser but am having trouble finding these.
Mike
#7
If you remote-mount your 790 and plug the speaker into the control head you'll be limited to 5 watts audio output. If you run the speaker wire back to the radio drawer you'll get the full 13 watts.
I run my external speakers to the drawers in my x90 radios.
n7maq-1
Oregon
#8
There is a 0 Ohm resistor that you can move to give you the full AO from pins 10/11 on the C/H. I don't know the R number off the top of my head, I'll look it up and update this post.
Jim
#9
Correct. According to the service manual you move a jumper resistor from R628 to R627.
I've never done this so use at your own risk.
timkilbride
Iowa County, Iowa
#10
On the 25 pin D connector, if I bring the audio out of pin 17, do I need to ground it with anything? I don't want to brick my radio. I'm using a TK-790 for a feed here, but need some audio!
TIA,
Tim
Kaceypaul
#12
No Audio
I just installed my TK 790H today, and have the remote kit hooked up. I have the ignition sense cable coming off the radio unit not the head. I have the sheet that shows the pinouts, and when I try and use either one of them, I don't get any sound. I tested the speaker and that works fine. It's just for some reason I cant get any audio at all. Any tips or thoughts?
Kaceypaul
#14
So if I read that correctly, I just have to run my ignition sense, and my speaker from the head unit not the big part of the radio?
Mi Wuk Village, CA, USA
#16
Shorted Pins?
Do pins on the 9 pin molex connector need to be shorted?
TK-790H
Full-featured Front Panel KCH-11 (remote mounted)
To use the speaker output from the KCH-11 in the dash (pins 10 & 11 on the 12 pin molex), do any pins need to be shorted on the base 9 pin molex?
Larry
KJ6QVI
Sonoma, CA
#17
Reference the diagram from post 15. It shows the jumper lead needed to route speaker audio to the control head. The jumper is between pins 3 & 6.
