TK-790 external speaker pinout
wcu02mpa
Asheville,NC
Does anybody know the pinout for the external speaker leads on a TK-790. I assume it is with the 9-pin plug and not the 25-pin plug.
Thanks,
Mike
wcu02mpa
Asheville,NC
That did it. This radio has amazing audio; it is a step up from the 730 for sure. It has very crisp and clear speaker audio as well as signal reports. I plan on remote mounting this radio. Do I run the speaker leads from the 9-pin when remote mounted. I see there is a 12-pin connector, but am not sure what that is for.
Mike
wcu02mpa
Asheville,NC
Part numbers???
I see it....DUH!!!! Firemaster.....would you happen to know the part number for the accessory plugs (from mouser or somewhere else)???? I would like both the 9 and the 12 pin plugs. I got some of the TK-730 plugs from mouser but am having trouble finding these.
Mike
mrweather
If you remote-mount your 790 and plug the speaker into the control head you'll be limited to 5 watts audio output. If you run the speaker wire back to the radio drawer you'll get the full 13 watts.
I run my external speakers to the drawers in my x90 radios.
n7maq-1
Oregon
There is a 0 Ohm resistor that you can move to give you the full AO from pins 10/11 on the C/H. I don't know the R number off the top of my head, I'll look it up and update this post.
Jim
mrweather
Correct. According to the service manual you move a jumper resistor from R628 to R627.
I've never done this so use at your own risk.
timkilbride
Linn Co Iowa
On the 25 pin D connector, if I bring the audio out of pin 17, do I need to ground it with anything? I don't want to brick my radio. I'm using a TK-790 for a feed here, but need some audio!
TIA,
Tim
ramal121
Lots and lots of watts
Calif Whine Country
Pin 17 AFO and pin 18 earth (ground) is a very good unbalanced audio level to feed to a sound card. Do it right and use shielded cable.
Kaceypaul
No Audio
I just installed my TK 790H today, and have the remote kit hooked up. I have the ignition sense cable coming off the radio unit not the head. I have the sheet that shows the pinouts, and when I try and use either one of them, I don't get any sound. I tested the speaker and that works fine. It's just for some reason I cant get any audio at all. Any tips or thoughts?
Kaceypaul
So if I read that correctly, I just have to run my ignition sense, and my speaker from the head unit not the big part of the radio?
toastycookies
the far east
external speaker installation / pinout
lrcrabtree
Paige, TX
Shorted Pins?
Do pins on the 9 pin molex connector need to be shorted?
TK-790H
Full-featured Front Panel KCH-11 (remote mounted)
To use the speaker output from the KCH-11 in the dash (pins 10 & 11 on the 12 pin molex), do any pins need to be shorted on the base 9 pin molex?
Larry
KJ6QVI
ramal121
Calif Whine Country
Reference the diagram from post 15. It shows the jumper lead needed to route speaker audio to the control head. The jumper is between pins 3 & 6.
