TK-790 Scan Current Channel
cdesio
Does anyone know how to include the currently selected channel in scan without adding it to the scan list? For instance I am on FG Red which normally doesn't scan but when on a scene we need to listen to it as well as scan everything else. When scan is turned on and the current channel is FG Red will ignore transmissions there but will jump to other channels that have scan enabled.
Northern,New York
Reprogram the radio and in the scan settings for pri 2 use selected. When programmed like this the radio will still have main pri channel but when you select the channel you want and put it in scan that channel also becomes a pri ch also
Doink
We always set the selected to Priority 1, that way the working channel overrides everything else.
