TK-860g Static after letting go of ptt
Wrench1
Hello,
I have a couple of TK-860G that we just put in some of our plow trucks. They are all programmed up and working well other than after TX when i let go of ptt they static for a couple sec like its monitoring the channel aloud. Any thoughts?
ramal121
Sonoma, CA
Are you running receive carrier quench? If so you may have to bump up the quench setting some.
If you have DQT on receive, it may be missing the turn off code. QT should work without a hitch.
Go for the quench first and see if that helps.
Wrench1
The channel is set up like this
RX 452.20000
TX 457.20000
qt/dqt dec 127.3
qt/dqt enc 127.3
The squelch is at 5 I will try and bump it up a little and see what we get.
Doink
A squelch of 5 is rather low and the Kenwoods generally have very sensitive receivers. Tighten up the squelch and you can also go into the radio options and enable off hook decode. This will force the receiver to listen for QT while you have the mic off hook as well.
Wrench1
So I set the squelch to 7 with no change. I have them set for off hook decode. We have an 880 in one of the trucks that we dont have this problem with and squels is set at 5 on that one. Any other thoughts?
