resq229
I bought a new TK-890h deck, it came with the krk-7db end cap, it was radio 2 of the original set.
I want to use it as a single band, single head. I installed a krk-5 end cap and hooked my head to it. the problem is that it will not power on at all.
I know the problem is the resistors need to be moved around, added or removed. I think I have to move resistor 705 to 602?? is this a 0 Ohm resistor? do I just remove the 705 and solder a jumper across the 602?
Then do I need to solder a jumper across R546 and R661?
its currently in the krk-7db configuration as radio 2 and I want to switch it to krk-5 single band, single head config.
Any help would be great.
