TK-940 Programming
Acton, CA
#1
I am looking for a "walk-trough" on the KPG-25d software for the TK-940 (800mhz) Radio.
I have been trying to get it right for a while now, but to no avail.
Does anyone have a "Template" that I could look at, to make sure that I am getting all the right information in the right places.
Or know what fields must have data in them.
Repeater Info: Area Code: ???
Home repeater Number:???
System Name:???
ALT-Feature Option-Data: System:??? Group:???
Trnspnd: Yes/No
TlkArnd: Yes/No
Data: Yes/No
Does anyone have a programming manual I could look at?
Thank You,
ROB
"SafeRanger "
Sonoma, CA
#2
This is more than three characters...
Does anyone have a "Template" that I could look at, to make sure that I am getting all the right information in the right places. If you are just trying to set up a voice group on a LTR system, are your repeaters correct and in the proper order? Is the ID a valid one for the system? I could send an archive if you think that would help, but you really need to get all the proper parameters in the right spot. See below.
Repeater Info: Area Code: ??? Required. Part of system info. Either a 1 or 0.
Home repeater Number:???Required. Part of system info. Range 1 to 20.
System Name:???Your choice. It's what shows on display.
ALT-Feature Option-Data: System:??? Group:???Leave blank. For sending data (like GPS).
Trnspnd: Yes/No Set as "no" unless you like weird beeping on the radio.
TlkArnd: Yes/No Set as "no". Used for direct car to car communications.
Data: Yes/No Set as "no" for voice communications.
Does anyone have a programming manual I could look at? Don't think there is one. Help files in the software is about all you're gonna get.
Thank You,
ROB
"SafeRanger "
Sonoma, CA
#5
cabletech; copy that!
My crusty old laptop has a bad floppy and I cannot get any archives out of it. Also I do not have any 940 codeplugs, however I have plenty of 840 UHF ones. 840's are the same as 940's except on the 940 the repeater freqs are entered by the FCC channel numbers. Google for a pre-rebanded 800 MHz list.
Since I can't get a codeplug, I emailed you screen shots...
