TK2180 with audio adapter
F5HPE
France
Hi Folks,
I have TK2180 kenwood hand held to program with the audio adapter like this one
WhatsApp Image 2025-03-28 at 12.23.18-Photoroom.pngWhatsApp Image 2025-03-28 at 12.23.28-Photoroom.png
Unfortunaly when my radio is programmed, the audio adapter doesn't swith the audio from internal TK2180 speaker to the jack via this audio adapter.
I tried several audio adapter and various microphone with an acoustic tube earpiece.
The audio doesn't switch.
Si I suspect a problem of proper set up of my radio.
So, what did I missed?
Can you help?
Many thanks.
Fred
Two possibilities come to mind. First one is that the audio adapter is bad. Pin 1 on the 14 pin universal connector handles switching between the speaker on the radio and the speaker on the speaker mic.
1 SSW I Ext/Int speaker switch input
L : External speaker ON, H : Internal speaker ON, Input voltage : 0V~5.0V
It's possible that the 5 volts was shut off in the programming software. If you go into the "Extended Function" window, make sure the "Universal Connector Pin No 11" option is set to "always 5 v (high)"
AM909
Radio/computer geek
SoCal
Have you tried just a regular speaker-mic (with no adapter)?
As informed by the manual quote above, it should switch to external speaker if you apply ground to pin 1 on the accessory jack on the radio (closest to the screw). Does it? You should see +5V pull-up on that pin with nothing connected.
I can imagine that since it is at the edge of the connector, and therefore the edge of the flex circuit, it is more vulnerable to be damaged.
F5HPE
France
Hi,
Thanks for your reply.
1 can be deffective not 15.
So I will check the programmation.
Many thanks for your advice.
Rgds
F5HPE
France
Many thanks for your comments.
Rgds
