TK8180
#1
Quick question, on the back of the DB connection, which pin outs will give de-emp and de-emp audio?
Am I right in seeing that:
Pin 19 = COS
Pin 7 = GND
Pin 3 = TX
Audio In = ?
Audio Out = ?
Ideally I would like audio at 1200 and 9600 if possible, due to a project that I am thinking of putting the radio to use on. I am hoping that this would be possible from the various pin outs on the back. I guess it's where they "tap" the audio from in the circuit
Every radio manufacturer has their own terminology for what they call each pin....
Any help would be appreciated.
Point Nemo.
#2
Here's the full pinout for the DB-25 connector on the back of the radio:
1. No Connection
2. RXD - Serial Data input 1
3. TXD - Serial Data Input 1
4. Aux I/O 9
5. Data Signal Input
6. External Mic Input
7. Ground
8. Aux I/O 8
9. TXD - Serial Data input 2
10. RXD - Serial Data input 2
11. Ground
12. Aux I/O 7
13. Aux I/O 6
14. Power Output in conjunction with the power switch.
15. Aux Out 2
16. Aux Out 1
17. Received Filtered Audio Output
18. Ground
19. Detected Signal Output
20. Aux I/O 5
21. Aux I/O 4
22. Aux I/O 3
23. Aux I/O 2
24. Aux I/O 1
25. ME (Mic Ground)
Many of the pins are programmable, using the KPG software and the HELP function will give you some more information. If you really run into some issues, let me know and I'll do what I can to assist.
#3
Got it! Thanks for the prompt reply.
So it should be possible to obtain de-emp and pre-emp audio?
I am unable to access the program at the moment hence the question.
If it is able to either tap via the pin or via programming, then this radio looks interesting
