I bought a TKR-850 from a local ham that was closing up his radio rental business. He had a stack of 850's in a trunking configuration, complete with controller, amplifiers and combiner. All were operational when I pulled it from the stack and took it hope, though it had been off the air for a little while.
The local community is a wealth of knowledge, and between documentation, phone calls, and a little bit of time, I was able to get the transmitter/receiver tuned up like new. Admittedly, there wasn't much to tuning required. Direct power out of the transmitter side is now 41.0W high and 25.4W low.
When I opened this box, the duplexer was already tuned/marked for 462.575/467.575. There was the factory duplexer alignment sheet sitting on top of the duplexer (attached). I attached my freshly calibrated NanoVNA to the duplexer, with a dummy load on the open port, and they seem to align with the factory sheet (sweeps attached). This "should" work just fine. I'm assuming the minor changes are due to test equipment, and the duplexer is just fine as it was, no adjustments made.
Here is the weird part. I was going to connect it to an antenna in my basement on low power just to test it out around the house and with a few HTs. To make sure I wasn't causing problems with too much RF, I hooked up the power meter with a dummy load to the output of the duplexer and tested on both high power and low power. I knew as a "mobile" duplexer it was "lossy" on high power already as I had tested that, but today, high out of the duplexer was 24.8W and low out of the duplexer was 22.8W.
That is -2.18db loss at high power, and -0.47db on low power. Frequency counter says it is right on frequency. What am I missing that the loss changes so much between power input levels? Looking up the duplexer part number, it's is a 50W rated Icom duplexer (photo attached), so I would assume 41W would be no issue.
Any ideas or help would be appreciated.
If this is more related to another section in the forum, feel free to move it.....
