TM9400 Multi-Body System Error
rkumetz
I am setting up a TM9400 multi-body single head system. I have everything assembled per page 16 of the TM9456 Dual-Radio Installation and Programming Guide.
The firmware is the most recent. Radios both have multi body support installed.
When I power up the system I get a system error.
I disconnected the UHF radio and was able to read and write the VHF radio.
I tried the same with the UHF radio but nothing so I swapped the body remote interfaces.
That allowed me to read and write the UHF radio. I also checked the primary radio box just in case that was necessary.
When I reassemble the whole system I am back to the system error.
Any hints?
rkumetz
That manual also references a "3301A2xx Dual Torso Programming Application" but nobody seems to know where to find that.
It is possible that the NTID's are not set correctly but there is no mention of where to check those or how to change them.
hrh17
Funny enough I'm having the same issue. The TM9456 works fine on custom dual body firmware but soon as I put standard 3.0 firmware onto the dual brick I get system error or Torso not found.
Ended up rolling back to the custom firmware
rkumetz
I was able to find the screen that lets you check & change the NTIDs.
As suspected the NTID for both radio bodies was the same and changing one fixed the problem.
The one thing that I am not fond of is that you need to edit both programs such that the info for the control head
is identical otherwise you may end up totally baffled if you write them in reverse order and the last one overwrites
what you thought you had set up. Allowing the option of writing to the control head or saving that data in a
different file might be more user friendly options for the dual band configuration.
rkumetz
What is the custom firmware? Both of my radio bodies have V3.x firmware in them.
hrh17
Flick me a PM
You'll need custom dual body CPS aswell
