TMR in Newfoundland
novascotian
Halifax, Nova Scotia
Just heard from reliable source that Newfoundland, at least the island part, will be joining the 700 MHz TMR system that already covers Nova Scotia, Prince Edward Island and New Brunswick. It will be Zone 3 of the system, and will include RCMP, RNC, Health.. the latter I guess is ambulances...
Deziel0495
PE/NB Database Guy
PEI
I know it was announced over 1 year ago that St. John's Regional Fire Dept. was upgrading their system to a new digital system. Perhaps it will be an expansion of the MPSRN. I haven't heard anything like this but it would be beneficial.
novascotian
One interesting thing about systems like this is that a portable in St John's will be able to talk to one in Edmundston, NB, crystal clear. Not that there would be much use for such a thing. I am not actually sure of what the advantage will be of having it be part of the Maritimes system, as there is basically no possibility of mutual aid type situations due to the Cabot Strait being in the way! We do get NL water bombers here in NS sometimes but aircraft are not on TMR, other than a very few exceptions.
novascotian
Another day, and a bit more info So this new system will cover the populated areas of the island of Newfoundland, as well as the main centres of Labrador. The initial plan is for 124 sites. Should replace whatever the RCMP, RNC and Health now have someday down the line with the provincial government system as well.
Deziel0495
PE/NB Database Guy
PEI
I had the topic pinned so it doesn't get lost.
Feel free to continue sharing info as it becomes available. We'll use this thread for any new TMR development in Newfoundland and Labrador.
novascotian
The aim is for the Avalon Peninsula to be done first, maybe in 2023. The rest will take a lot longer. Looks like Labrador will be the bigger centres only and not like chains of sites along the connecting highways.
VO1IV
NEWFOUNDLAND
Good day folks, I am receiving what seems to be P25 control channels from various sites:
CGB665 769.0812 NAC681 BAULINE NL
NOCALL 769.1062 NAC689 GOULDS NL
NOCALL 769.1312 NAC684 BELL ISLAND NL
CGB666 769.1562 NAC682 LOGY BAY NL
CGB916 769.18125 NAC689 QUIDI VIDI NL
CGB683 773.18125 NAC683 ST. JOHNS WEST
I have no way to find the talk group ID`s. All I can confirm is this information at this time. Received on a Uniden BCD996P2, Antenna is a Diamond X50A at 660 feet above sea level.
73! VO1IV
Deziel0495
PE/NB Database Guy
PEI
73! VO1IV
Good to know, thanks for the info!
Are any of the sites reporting a System ID?
If you program in the control channels for the sites you are receiving, and put it in "ID Search" rather than "ID Scan" it will find any active talkgroups.
BC_Scan
Vancouver BC
The scanner will do it for you. Program each control channel into a separate group with ID search on and the scanner will do the rest.
You will then have IDs, the rest is detective work.
VO1IV
NEWFOUNDLAND
Okay folks, with some programming and monitoring I have noted the following:
BAULINE 769.08125 = SID 0687h-0321
GOULDS 769.10625 = SID 0687h-0309
QUIDI VIDI 769.18125 = SID 0687h-0319
LOGY BAY 769.1562 = SID 0687h-0302
ST JOHNS WEST 773.1812 = SID 0687h-0303
I am now searching for TGID`s. Will keep everyone posted.
Deziel0495
PE/NB Database Guy
PEI
Thank you! I can add this info into the database.
VO1IV
NEWFOUNDLAND
31 JAN 2023
Good day all, I've been monitoring the P25 system here for a few weeks now and I have been able to confirm some things.
BELL ISLAND 769.13125 = SID 0687h-0304 = NAC684
HOLYROOD 773.18125 =SID 0687h-0305 = NAC685
----------BT---------
BAY BULLS 769.16875 (CONTROL CHANNEL OPERATIONAL, NO FURTHER DATA, WILL ADVISE)
COLLIERS 770.58125 (CONTROL CHANNEL OPERATIONAL, NO FURTHER DATA, WILL ADVISE)
CHAPEL ARM 770.19375 (CONTROL CHANNEL OPERATIONAL, NO FURTHER DATA, WILL ADVISE)
PETTY HARBOUR 769.30625 (CONTROL CHANNEL OPERATIONAL, NO FURTHER DATA, WILL ADVISE)
VICTORIA 770.59375 (CONTROL CHANNEL OPERATIONAL, NO FURTHER DATA, WILL ADVISE)
SPANIARDS BAY 772.13125 (CONTROL CHANNEL OPERATIONAL, NO FURTHER DATA, WILL ADVISE)
----------BT----------
TGIDS
20 = ? VOICE
21 = BELL RADIO TEST 1, RX VOICE
22 = BELL RADIO TEST 2, RX VOICE
23 = BELL RADIO TEST 3, RX VOICE
24 = BELL RADIO TEST 4, RX VOICE
37000 = JRCC HALIFAX, RX COMMUNICATIONS BETWEEN JRCC & OTHER STATION. (NL SITES PATCHED TO SYSTEM WIDE?)
More to follow. 73!
VO1IV
NEWFOUNDLAND
02 FEB 2023
More sites, as promised. Will continue monitoring for more traffic and TGID`s
COLLIERS 770.58125 = SID 0687h-0306 = NAC686
CHAPEL ARM 770.19375 = SID 0687h-0307 = NAC687
VICTORIA 770.59375 = SID 0687h-0320 = NAC680
SPANIARDS BAY 772.13125 = SID 0687h-0308 = NAC688
MOBLE 770.53125 = SID 0687h-0318 = NAC688
CAPE BROYLE 771.85625 = SID 0687h-0312 = NAC68C
73!
Deziel0495
PE/NB Database Guy
PEI
02 FEB 2023
73!
Appreciate the info. I got it all added to the database. If there are any errors or omissions, please let me know. In addition to posting here, you can also submit directly to the database (incase I don't see it here) using the link below.
