TNC to BNC....or just replace?
natiep
St. Paul, Minnesota
Hello Everyone!
I just received this antenna which I bought from ebay to use with my PRO-197 scanner on the 850MHz digital frequencies:
http://lib.store.yahoo.net/lib/yhst-83245474170555/spec-0603.pdf
It comes with a TNC male connector. Can I buy a TNC male to BNC male to connect it to my scanner, or should I just cut the TNC male connector off and just attach a BNC connector?
Thank you for your help and comments.
davidgcet
i would cut it off and replace the connector.
as a side note, you can pop the threaded collar off the TNC and *poof* you now have a universal plug in male connector that will fit N/TNC/BNC.
davidgcet
sure it will, so long as nothing pulls on it. they are great for quick connects while testing, though certainly for extended use you want the proper connector for a solid connection.
N2KMB
B11D
B11D
i would leave the TNC they work till around 3ghz with not much loss the last time i looked but i could be worng
zz0468
Banned
Below 1 GHz, even mediocre grade adapters have less than 0.1 db loss per adapter. I got curious about the frequent claims about how bad they are, so I measured a bunch. Adding a TNC to BNC adapter is absolutely insignificant at 1000 MHz or below.
natiep
St. Paul, Minnesota
Thank you all for your help and comments!
The markings on the cable are: 5D-FB coaxial cable. Can I crimp on an RG6 F connector to this cable?
davidgcet
why would you want a F connector if you need BNC? if the center conductor is stranded, you can't use an F anyway, as it uses the solid center conductor as the center pin.
davidgcet
basically it is a BNC with threads instead of the twist lock.
