Tone Out Ringtones
kendrik578
Live Audio Administrator
Greensboro, NC
Was curious if anyone uses fire tone out for ringtones, or any other kind of interesting ringtones. If so, where do you get them?
Thanks!!
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
You can find stuff from the show Emergency, many places. Most anything else, you would have to make yourself.
Various sirens are available, if you look.
parkerbs
Aiken, SC
i can make them and so can you
I used the program audicity to make mine, I just made the fires tone for one second and the second tone for 3 seconds, set my phone at the fd and called it from the next room, its good stuff.
Rt169Radio
CT
Could you record fire tones from your scanner and then convert them into whatever file your cellphone uses for ringtones?
parkerbs
Aiken, SC
absolutely, most modern phones use an Mp3 format for ring tones and alert tones, using Audicity along with the Lame add-on you can convert the audio from one format to another. so if you record in .avi you can convert in to mp3 or vice versa. That program is awesome.
Rt169Radio
CT
Maybe the OP could try that.
kendrik578
Greensboro, NC
Yea im aware i can make my own, im just having a hard time finding some good quality tone outs that i like.
