I live in Richmond Hill but drive down and up the DVP each weekday and work right downtown by the lake. I've looked at the settings (as they were downloaded from the RR database, unchanged by me) and this is what I uploaded to my scanner:
System Type Mot Type II / P25- This might be a problem, I dont think its a P25 system
Motorola Status Bit OFF-Try turning it on
Motorola End Code OFF Turn it on
Digital Motorola End Code OFF
Enable I-Call OFF
EDACS ID Format DECIMAL This is not a EDACS system
ID Mode ID SCAN
Tape Out ALL CHANNELS
Site Type Mot 900MHZ Band
APCO Mode AUTO
Threshold 8
Modulation AUTO
Locked Out OFF
20dB Attenuation OFF
Control Channel Only OFF Turn this to on and enter in all the CC's listed
Trunk Frequencies are as they are in the DB. None are locked out.APCO Band Plan (since it doesn't apply) is all zeroes.
Talkgroups are all set to ANALOG ONLY.
On my way into work this morning, driving down the DVP, I held on one of the control channels. Got lots of motorboarding on 938.4375 and heard voices on some of the other control channels. Switched my scanner from ID Scan to ID Search but still got nothing when scanning the entire system. I'm at work now and it's the same situation: nothing when scanning but voices and motorboarding when holding on the control channels.
Any ideas based on all of that about where I've gone wrong?
Cheers,
Rob
