Torrington FD still using VHF or have they completely transitioned to CLMRN?
n1chu
Farmington, Connecticut
I would like to use a UNIDEN BCD996XT (as opposed to the BCD996P2) to monitor Torrington FD on CLMRN. First, will the XT version work for CLMRN? Secondly, if the XT does work on CLMRN, can I program it MANUALLY? I can see the frequencies listed on the RR database. Do I need to enter all or just control channels? And, I’m not sure on what additional parameters I would need to program. I realize I could program with all frequencies listed for Torrington or just control channels but if I don’t have those additional settings (parameters) set correctly I won’t know if either set of frequencies work. I only have a need to monitor Torrington FD.
sefrischling
Public Information Officer
New London, CT
The 996XT is P25 Phase I only; it will not monitor CLMRN. I have one in my truck, I love it, however, if you want to monitor CLMRM you need a Phase II capable scanner.
I had severe problems with CLMRN and multiple 996P2 radios. I got the SDS 200 and it works perfectly. Some people use the 996P2 without issue, but after my issues with multiple units, I won't try that again.
n1chu
n1chu
Thanks for the reply. I guess I need a P2 version or an SDS model. My application is a simple one, just monitoring Torrington FD. If they are not simulcasting on their old VHF High band frequencies then Im out of luck.
W1KNE
PITA from New England
New England
As of about two weeks ago they were still on their VHF. I was also hearing the PD on the VHF too, but I suspect that won't last.
@nhfdcadet would know for sure. Also with CLMRN , especially in places in Litchfield County where you can receive multiple sites easily due to terrain, you'll want the SDS. The 996P2 is terrible with simulcast, and the 536hp, while better, is still pretty bad.
cg
Connecticut
Unless you are monitoring from Torrington, I would suggest using CLMRN so you will also hear the fireground traffic.
