Tough 2 meter antenna request
W8FFG
Hi all!
I know that this may be a tough one. My Sister WD8HU Mary is a disabled person who lives in an apartment. I set her up with a diamond mag mount antenna with a metal plate on the windowsill in which she can get into a repeater 40 miles away marginally. It has a good low swr. I have racked my brain trying to think of some sort of compact directional high gain antenna that she could use in her apartment to get into the repeater reliably.
Many many thanks in advance for any suggestions.
W8FFG. Bill
I needed a UHF Yagi to DF some interference. It was at the start of COVID, so it was long lead times for anything I'd order.
I built one of the "tape measure" Yagi's and it worked surprisingly well. Nice thing about it was that it was nearly unbreakable, so as I was driving around taking plots, I could just toss it in the back of the truck.
Might be a good, easy to build option for you, and since it's unbreakable, it's pretty tough.
Bonus points for using the "free" tape measures they are always giving away at Harbor Freight.
AB4BF
EM93cs
Hi all!
W8FFG. Bill
Is there any way you could mount the plate at the top of the window and then mount the antenna underneath the plate pointing down? If the window is tall enough, that could give you two to three feet of more height. Just a little bit of height sometimes gives good results. Or, mount the plate on the ceiling or eave if that is where the window is. That would give two to three feet even more height. Just thinking outside the box...
hazrat8990
Wyoming
Any thoughts of building a simple J-Pole?? Quick and easy to build, has a bit of gain, and doesn't require a ground plane.
AK9R
Staff member
Super Moderator
Central Indiana
J-poles are, in essence, end-fed half-wave antennas. They have the same gain as a half-wave dipole. They may have some apparent gain over compromised antennas, such as handheld rubber ducks. With J-poles, you also need to be very careful of their surroundings. The lower quarter-wave portion of a J-pole is a transformer. Metallic objects in the field of that transformer can have negative effects on a J-pole.
nd5y
Wichita Falls, TX
Why not? It's a simple and cost-effective build and it works.
If J-poles are so good then why are they not currently or ever in the past made by Andrew, Decibel, Phelps-Dodge, Commscope, Comprod, Sinclair, Telewave, etc. and why do you never see them in commercial or government installations?
rf_patriot200
Freeport, Illinois
J poles are Cheap to build and work well. Those companies haven't gotten where they are today by going with "cheap". They LOVE $.
mrweather
Never said they worked well. But ham radio is about experimenting and doing things yourself.
I've built a few "copper cacti" over the years and they were durable and worked.
Echo4Thirty
Colorado Springs, CO
Some commercial entity is making them. I see them from time to time for data radio usage. Typically flood or air quality monitors.
Echo4Thirty
Pffft. If that were the case they would have all of them on AllStar on the East Coast Reflector!
or or or on all 8 GMRS pairs! lol
Seriously though, is that the reason? I can find ZERO commercial J-poles and have always wondered if they went with a cheap ham antenna and retuned it to the 170s. It woudlnt be the first commercial install I have seen do that.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Yes, that's the reason. A lot are now a mobile antenna with a ground plane kit.
bill4long
Indianapolis
J-Poles have a null, which one should be aware of.
bill4long
Indianapolis
Hi all!
W8FFG. Bill
1. Does she have a balcony?
2. Would management allow a small antenna in the attack?
3. How about a vertical dipole hidden up in a nearby tree?
4. Maybe setup a remote using Allstar, IRLP or EchoLink, from her apt to somewhere near the repeater.
Etc. Time to think way outside the box.
There's no big deal with J-pole antennas. They are 1/2 wave and it's easy enough for a commercial company to build a suitable antenna that works better.
I think the only reason the hams like the J-poles is because they are easy to build with minimal experience. I had one as a new ham and it worked well, but it wasn't anything spectacular.
RFI-EMI-GUY
Hi all!
W8FFG. Bill
If maybe she is on the wrong side of the building or a ground floor, perhaps management or neighbor would allow her to install a remote base on that repeater pair in another apartment or common area?
