Tram 1199
Lake County, OH
#1
Point Nemo.
#3
Keep in mind that while the marketing speak in the description says it'll cover down to 25MHz, reality is that a short antenna like either of those is going to be a very poor performer for low band VHF.
You can't cheat physics. Using an antenna that small and expecting good results on low frequencies is setting yourself up for disappointment.
cvfd625
Bakersfield, CA
#4
I think the through the glass part is what made it so bad for me.
Sent from my SM-G930V using Tapatalk
Lake County, OH
#5
Well I'm using a wire antenna in my windshield now that isn't horrible. So I think the tram will work good too and if it isn't I will go with a comtelco all band or a Larson triband.
