Tram 1240 nmo question antenna size
#1
This is a 5-inch 120 pound pull strength magnet mount what is the maximum size antenna that safe to use with this? Is there any chart or guidance for the amount of pull strength 2 antenna size
Sent from my SM-N920T using Tapatalk
PA
#2
Not really, because the actual pull strength depends on the thickness of the metal it is attached to. Which varies depending on the vehicle, as well as where you stick the mount. If you place the mount where a support member is directly under the magnet, you'll get a better "stick" than between support members.
#3
Okay thank you I wonder how I locate the support beams in the roof of my Ram truck
PA
#4
If you press firmly on the sheet metal it will "give" or flex a little between supports. But it won't where the supports are.
