I've never seen any of their base antennas, so no help there.
I have looked at their mobile antennas at various trade shows, and was not impressed. Chinese produced antennas for a few bucks less than the known US brands. I've preferred to stick with Larsen for most of my work and personal mobile antennas.
As for discone antennas, they are good at one thing, and one thing only- broad frequency use. They have zero gain, so are not stellar performers, doesn't matter who you purchase from.
If you must have a super wide band antenna and are willing to only install a single antenna, then a discone is probably a good choice. If you only need to listen to specific bands, or can properly combine antennas, dedicated single band or dual band base antennas will out perform a discone any day.
If the discone is the right choice for you, just make sure you install it properly, that includes proper grounding, sealed coax connections/weatherproofing, etc. Use decent quality coax to get the most performance out of these antennas. Since they have zero gain, you need to make sure you get as much signal down to your radio as you can.
