Tram 1470 Radials
teebee
Lake Charles, LA
I just received a new Tram 1470 kit. The ground plane radials it came with are very thin as compared to my custom cut radials I am using on another set which are cut to 700/800 Mhz. Does it matter on the thickness of the ground radials for these antennas or wound the thicker ones work better. I can either cut the new radials to length (4") or try and drill out (if possible) the 4 holes on the mount to fit my current radials?
MDScanFan
USA
I can't imagine that increasing the radial diameter a bit (ex: 1/16" to 1/8") would have a noticeable impact on the performance of the radial kit. You should be fine with what it comes with.
teebee
Lake Charles, LA
Are Ground Plane radials beneficial to reception on 700/800. I see some base antennas with them and some without. As noted I purchased the TRAM 1470 and will be trying it out soon, however I noticed another one similar from Laird. Its the MBC800. Anyone tried it as compared to the TRAM 1470.
