Transmitting Tones HT-750
Drachen_Fire
Center Township, PA
#6
There is no tone standardization in the CPS for the Waris series, so yes it will do Plectron tones. My previous fire department used two Plectron tones for alerting that they've had since the 1960's, and the HT1250 does it just fine.
Some random guy on the internets.
Point Nemo.
#10
IIRC, the 750's can't do QCII encode or decode. You'll need a 1250 for that. (I'm not near my programming lap top to verify that but I do know for sure that the CDM750's won't do QCII.)
Thanks for the correction. That makes a lot of sense, the CDM750/1250 are the same way.
