Travel I-77 from VA line to Columbia then to I-95.
kb3isq
Shippensburg, PA
Will be traveling I-77 from Va line to Columbia and then I-26 to I-95, What do I need to monitor NCHP on my PSR 500?
kd8x
NC
Program the NC Viper system... SHP is using that.
some sites from viper to have in scan list are Turner, Elkin, I77, Barium Springs, Mooresville, Huntersville, Pineville....That will pretty much get you to the SC border.
FireCop
Mooresville, NC
You might want to add Fisher's Peak with Turner Mountain. Both cover some of the same area with Fisher's Peak having the altitude edge. I'm not sure of their footprints and covering I77 though.
Also, the I77 he has listed is the Yadkin County Rest Area site just south of I77 and US 421.
Hopefully those will help clarify things a bit. Thg other sites should be spot on.
KE4ZNR
KE4ZNR@radioreference.com
Thanks for the info! I'll try to put those in manually this weekend. I wonder when the database might get updated to include this new license in the list of NC VIPER sites. I'm not sure how that works.
All any RR.com member needs to do is tap the big "SUBMIT" button at the top
of each and every page here at RR.com and submit the updated info. :)
Us database admins can't update what we don't know about.
Marshall KE4ZNR
